Re: Farmall H quits running.
Posted by JayinNY on October 04, 2009 at 17:20:03 from (67.72.98.45):
In Reply to: Re: Farmall H quits running. posted by rustyfarmall on October 04, 2009 at 17:12:59:
I have checked the fuel cap for vapor lock and it did not make a sucking sound. However I did not check the coil! I thought a coil either worked or it dident, or could it be intermitten? Also after a few minutes the tractor will start right up again, but only run for a few minutes. I will check the coil after I run it and it quits again. Thank you. J
