Re: Farmall H quits running.
Posted by rustyfarmall on October 04, 2009 at 17:12:59 from (209.152.78.140):
In Reply to: Farmall H quits running. posted by jayinNY on October 04, 2009 at 17:00:25:
The next time it stops, immediately get off and feel the ignition coil. If it is too hot to touch, or at least very warm, there is your culprit. If the coil is not hot, then remove the fuel tank cap. If you hear a suction sound while removing it, that means the vent is plugged. Easiest fix is a new, vented fuel cap.
