Re: International A-1 Steering
Posted by Hugh MacKay on October 04, 2009 at 18:49:12 from (209.226.247.17):
In Reply to: Re: International A-1 Steering posted by TWheat on October 04, 2009 at 18:04:54:
TWheat: OK, between you and Sam I think you have me straightened out. I thought you were talking about the vertical shaft within the gear box. I best bow out as I know very little about that brace with the industrial front end. I never had one.
I'll also take the time to straighten you out. You said International A-1, should have been A-I, there is a difference. There is an International A-I and an International A-I-1 There is also a Farmall A-1, all different. You did contribute, ever so slightly to my confusion, ,more than slightly was my 67 year old dead brain cells. At least that is what the Doc. told me after a recent MRI, no anurism, no cancer, just normal dead brain cells for a 67 year old. Heaven forbid, I'm loosing my tractor brain cells.
