Hugh, you're correct, "clutch housing", not bell housing. The shaft I mean is the one on the A-1 and I assume other "heavy duty"(triangle shaped, not round) axles and runs on back to and bolts to the clutch housing . I want to remove that pivot shaft. Thanks
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
