Re: Farmall H quits running.
Posted by glennster on October 04, 2009 at 20:17:26 from (24.14.63.246):
In Reply to: Farmall H quits running. posted by jayinNY on October 04, 2009 at 17:00:25:
i have a farmall b that would die ocassionally without warning. then restart fine. finally found the problem. soybean was in the fuel tank. would cover the fuel inlet, tractor would die, then the bean would roll off the inlet.
