Farmall H quits running.
Posted by jayinNY on October 04, 2009 at 17:00:25 from (67.72.98.45):
I have a 1947 H, after running from anywere between 1/2 hour to 1 minute it stalls. It has fresh gas in it with dry gas, I put on new plug wires and plugs, glass seditment bowl is clean, the manual said to clean a screen in the carb, checked mine hopeing that was the problem, not plugged at all.
Other than points and condenser or rotor, which I havent really checked what could make it keep stalling? I would think it would be a fuel problem! dunno. I did pick up a carb rebuild kit last fall, but havent put it on yet. I really like the tractor, but this is fustrating. I have two Ford diesel tractors that do the work, but I wanna get this H running right so it can be used if needed, without having to leave it in the field until the next day when it will start so I can get it back to the barn! thanks j
