new to me 706, need advice
Posted by Rtkman706 on October 05, 2009 at 12:48:40 from (75.120.176.185):
I just bought a 706 for my first tractor (hopefully didn't pay too much).
I have few things to work on and would appreciate some advice or experience with these issues:
1) Power steering-takes about 2-3 minutes after startup of working it back/forth to function.
2) Brakes not working well. Adjustment or hyd. system?
3) Some antifreeze leaking at back of engine near head/block interface, but no oil in antifreeze or vice versa. Need head gasket?
4) Some blowby, light oil smoke under load. Almost 7000 hours, when to rebuild?
thanks
