Re: STARTING MD
Posted by Haas on October 06, 2009 at 20:07:25 from (70.220.201.154):
In Reply to: Re: STARTING MD posted by Haas on October 06, 2009 at 20:02:50:
The switch over lever has four functions. It opens (for gas running) the compression release valves in the cylinder head and closes them for diesel running. It changes butterfly valves in the manifold to direct air through the carburator for gas running. It turns the ignition on for gas running. and finally when you switch to diesel, it lifts the float in the carburator to shut off the gas flow when running on diesel. This is a complicated linkage and if not adjusted properly you will have problems.
