Re: 6 volt or 12 volt Gen
Posted by CNKS on October 07, 2009 at 09:26:54 from (216.144.104.128):
In Reply to: 6 volt or 12 volt Gen posted by kevin baird on October 07, 2009 at 09:17:09:
What tractor--12 volt appeared on the late 450's I believe, and other models were gradually changed. As a short cut if the generator has a black tag it is 6 volt, red tag 12 volt. That is not all inclusive as 6 volt ones can be converted to 12. If it is an A through early 450, it was 6 volts from the factory, with the exception of diesels. And, "most" 12 volt conversions use alternators. Electrical people on this forum will tell you how to test it to be sure.
