Re: 6V generator
Posted by Janicholson on October 09, 2009 at 14:42:46 from (64.61.211.175):
In Reply to: 6V generator posted by heneryv1111 on October 09, 2009 at 14:26:16:
Your guess is correct. Use a small socket that is just a tiny bit smaller, and it will come out easily.
I like to use a vice and a larger socket to drive it into. Bushings are common at NAPA and other stores. Make sure it is an oilite (sintered bronze) bushing. and all is well. JimN
