Posted by Janicholson on October 09, 2009 at 14:56:46 from (64.61.211.175):
In Reply to: My IH 544 won't run now. posted by Eric Kaltenbach on October 09, 2009 at 09:15:28:
Clean and set the points. Make sure there is ignition voltage going to the coil with the ignition on (not the start position) There may be a bypass that allows the ignition to get voltage when cranking (from the starter relay, that little can on the starter). It is connected to an "I" terminal, on the relay (if there are only three terminals on the relay, ignore this possibility), and to the coil side of the ballast resistor on the coil end. This will provide that "starts when cranking then quits when turned to run" symptom. A bad ignition switch or ignition wire will cause the actual problem. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
