Re: H Steering wobble
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Ioway Boy on April 21, 2000 at 19:04:28 from (209.240.216.84):
In Reply to: H Steering wobble posted by Ed E on April 21, 2000 at 16:49:11:
I had a problem with aborrowed H and then M I bought.Front wheel bolts looked fine but were loose.Tightened them.Solved my problem.
Post A Followup
: Re: Re: H Steering wobble
