Re: Super A wont start
Posted by Jeff Z. on October 11, 2009 at 09:01:37 from (74.76.3.113):
In Reply to: Super A wont start posted by scott#2 on October 11, 2009 at 08:41:44:
You can try ATF or spray PB Blaster in and keep adding. Most will get by the rings.
Open oil pan and let excess drain out.Add more every day. Do this for a week.
If you get it started the more you run the engine the better it will get as far as the rings unsticking.
