Super A wont start
Posted by scott#2 on October 11, 2009 at 08:41:44 from (138.88.85.33):
Cleaned the whole fuel system, pretty nasty, rebuilt the zenith carb, all back together and wont start.
Tried a shot of starting fluid in the carb throat, no dice.
Got the compression guage out and no cylinders will go over 25 lbs. This thing was running and pretty good, last year.
Whats your mix and procedure for freeing stuck rings?
