Posted by scott#2 on October 11, 2009 at 09:27:16 from (151.200.15.212):
In Reply to: Super A wont start posted by scott#2 on October 11, 2009 at 08:41:44:
Thanks for the reccomend on the soak, pulled the v/c off, found a bent push rod and 3 stuck valves and one partially stuck. To free them up, I tapped them down as far as they would go (one at a time), one came back on spring tension, the other 3 needed to be pushed up and down a few times to free them up, their still sticky so will stay on them with soaking.
What I did was tap one all the way down and slowly hand turn the engine and let the piston push it back up a little and repeated this until I could eventually pry them back up with a big screwdriver under the retainer, then repeat on the other ones. So far looks like I got lucky by getting to them before they were really rusted up, never had this happen before. It stays outside with the stack covered, guess weve had more humid days than usual around here. Moral of story, run your stuff every couple months.
Rings might still be stuck, need to do one thing at a time.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
