Re: SA not charging, again, would like to fix, once and f...
Posted by scott#2 on October 12, 2009 at 10:53:04 from (138.88.61.151):
In Reply to: Re: SA not charging, again, would like to fix, once and f... posted by scott#2 on October 12, 2009 at 09:48:08:
Just grounded the f term and the meter goes to charge.
With the wire connected and the engine running, lights off I am reading 6.32 vdc and increasing at the batt.
With wire on, eng running, lights on, volts at the batt are dropping, not enough output to stay up with the light drain.
With the same above and at the generator, I read 6.73 at hi thrott.
When I turn the lights on, it drops down to say 6.5 (at the generator) then builds back up.
With F jumped to ground and the lights on, the volts at the battery increase every second or so. If I drop it to idle, the volts drop rapidly.
Next ideas???
Scott#2
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
