SUPER A HYDRAULICS
Posted by V10nacuda on October 12, 2009 at 12:18:40 from (205.188.116.12):
Just got a recently purchased Super A out to do some work... Found out the lift is real slow!!!!!! If I work the rear lift up it moves real solw....Then if I move the front lift back & forth (no implement attached) it lifts the rear one in spurts....
So I drained the fluid & it was OK as well as the screen in the left side. So I decided to change the oil also & it seemed rather clear. Drained it & refilled everything & it appears that the hydraulic fluid is getting into the crankcase....
1) Is the hydraulic pump seal failure the only way for fluid to get in the crankcase???
2) Is there a rebuild kit for the pump?????????
Any help would be appreciated...Snows coming & I hope to plow with this little thing.
Thanks
V10
