Re: SUPER A HYDRAULICS
Posted by CNKS on October 12, 2009 at 13:30:43 from (216.144.104.128):
In Reply to: SUPER A HYDRAULICS posted by V10nacuda on October 12, 2009 at 12:18:40:
1. Yes, 2. No. You need a seal for the pump, it is either a normal seal or an o-ring. If the shaft where the seal runs is grooved you need a speedi- or redi-sleeve (trade names) over the shaft. If an o-ring the hole the shaft goes through will have to be enlarged to accept the sleeve. Take it to a machine shop for accuracy. Rather than the pump, the block under the tank probably needs to be overhauled. Otherwise you need a new pump. CaseIH sells a kit containing mostly gaskets and seals for $100+. Yours is a common problem. The kit is LOT cheaper than the pump, try that first.
