Posted by Owen Aaland on October 13, 2009 at 10:18:06 from (65.165.246.152):
In Reply to: To Tractor Vet- 1486 posted by Larry B 1486 on October 12, 2009 at 18:32:26:
You need an answer to the question about smoke.
If you have poor compression you should have excessive blow by out the vent tube. If the blow by is not excessive then if you are getting the fuel to the engine you should be getting smoke if you can add the fuel. If you have a bad cam or lifters, or if you have restricted air intake, or a bad turbo, all will reduce the air intake and the excessive fuel should cause smoke.
Have you double checked the timing? If the advance in the pump was not ion the retarded position when the pump was installed it is possible that the timing was set late even when the marks lined up.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
