Re: To Tractor Vet- 1486
Posted by Owen Aaland on October 13, 2009 at 16:22:34 from (65.165.246.121):
In Reply to: To Tractor Vet- 1486 posted by Re: 826 fuel problems???? on October 12, 2009 at 18:32:26:
bc said: (quoted from post at 18:47:13 10/13/09) Larry, I think what everyone wants to know is how much smoke and what color it is coming out of the exhaust pipe both under load at full throttle and at idle and if the amount of smoke increases much between idle and full throttle under load.
It's not necessarily oil smoke or oil usuage or oil pressure but to evaluate the pump they want to know the amount of black (or white) diesel smoke it puts out. Then they can judge whether the tractor is not getting enough, getting enough, or getting too much diesel in their experiences.
Blue oil smoke out the exhaust and alot of blue smoke out the blowby tube is only one of the things needed to know to see if your power problems are compression related. The smoke out the exhaust may determine if it is pump related or not.
And then how does the exhaust smoke compare to your other tractor that you say is ok.
That is exactly what I meant. You just stated it much more clearly.
