Re: Farmall M - Radiator Leak
Posted by Melvin Ware on October 13, 2009 at 21:20:56 from (4.152.108.176):
In Reply to: Re: Farmall M - Radiator Leak posted by ScottyHOMEy on October 12, 2009 at 15:28:09:
Scotty,
As for removing the nuts from the studs at the bottom of the radiator, you said only an open end wrench will work. However, on my "M" there are access holes directly below each stud through which a socket and extension fit nicely. The nuts have a lot of grease on them and turn easily so they should be easy to remove. Feels like there may be a spring and washer on the end of each stud. Now I need to know how to get the steering shaft separated and out of the radiator.
