Super A Carb question
Posted by Tom/Idaho on October 14, 2009 at 09:36:46 from (216.57.174.229):
Zenith carburetor # 52499 9752 DB
The carb is missing plug #16825D (gasoline) (main jet passage)
OR
adjuster # 53786D Valve, needle Main jet adj. (distillate or kerosine)
Parts list shows both, but obviously only need one.
Would I need just the plug as it will only burn gas? Thanks for any assistance, Tom/Idaho
Serial # on tractor is 252960 which I believe in 1948 Super A.
