Re: Super A Carb question
Posted by rustyfarmall on October 14, 2009 at 10:42:50 from (209.152.78.140):
In Reply to: Super A Carb question posted by Tom/Idaho on October 14, 2009 at 09:36:46:
The adjustable one will allow you to fine tune the fuel mix to suit the way you use the tractor. In other words, if the tractor sees only light use, you can lean out the mix for greater fuel economy, and then if you decide you do want to work it hard, you can then adjust for a richer mix to give better power and performance.
