Re: Early 40's H
Posted by Andrew Z on October 20, 2009 at 05:13:14 from (64.252.130.179):
In Reply to: Early 40's H posted by Jeremy T on October 19, 2009 at 19:46:00:
detergemnt oils contain 'clearners' with them they break down sludge and despoits in the engine. when they do it goes in suspension and is then caught by the filter. however after years of use and most often lack of oil changes this sludge really builds up. if you put detergent oil in there it may losen up the sludge and block an oil passage. if you drop the oil pan and clean it out real well then it will be ok to use detergent oils until then i use non detergent. at least thats the way i do it.
Andrew
