It should make ~1200 psi at 12 gpm if I remember right. They are not known for lasting long if used heavily at high pressures. It takes out the cam gears. (only on the gas models) A rule of thumb to remember is the belly pump rate 8 at 800, and the distributor pump is 12 at 1200. Not exact, but close enough.
