super md live hydraulic pump
Posted by Andrew Z on October 21, 2009 at 10:24:36 from (64.252.130.179):
im working on my super md in which i plan on hooking up a loader to it. anyway today i hooked up a line from one of the outlets on the left side of the res. to a cylinder on a loader to see if it would lift it or not. it would lift it but would not hold it up at all! it would just fall right back down. im thinking that the relief valve is bad or the pump its self. the only thing that i see that is odd is the lever on the side of the res only has two postions not '3' like a belly pump. it seems to only have up and down no netural positon? i plan on routing the loader though a spool valve but shouldnt it work this way as well? any thoughts as if the pump or valve is bad?
thanks for the help
Andrew
