Farmall M - Steering Shaft Seal
Posted by Melvin Ware on October 25, 2009 at 15:03:31 from (4.152.108.201):
It was suggested that while I have the radiator off my Farmall M I should replace the steering shaft seal. My question is, how do I safely remove the old seal and install a new one? Do I also need to replenish the grease in the steering mechanism which I assume is done by removing the round cover plate from the top of the steering fork. How much grease is needed and how full should it be? If unable to find the recommended "corn head" grease here in SC is there an alternative lubricant I should use?
