Re: Farmall M - Cooling System
Posted by Nebraska Kirk on October 25, 2009 at 19:27:56 from (207.91.4.162):
In Reply to: Farmall M - Cooling System posted by Melvin Ware on October 25, 2009 at 18:54:04:
Melvin Ware said: (quoted from post at 18:54:04 10/25/09) Can anyone tell me the amount of coolant a Farmall M will hold and if the standard 1:1 mix of antifreeze and water is okay? Also, what is the pressure rating of the radiator cap and temperature rating for the thermostat? (Maybe someday I'll buy a reference book for my Farmall.)
Cooling system holds 6 gallons. I always use a 50/50 mix of antifreeze & water, if you live in a colder climate, you may want to increase the amount of antifreeze. Thermostat opens at 165 degrees, fully open at 195. My book does not say anything about the pressure rating of the radiator cap, 5-7 lbs. I would imagine.
