Re: rust inhibiting coolant?
Posted by Michael Soldan on October 26, 2009 at 17:08:33 from (24.235.49.88):
In Reply to: rust inhibiting coolant? posted by Mike CA on October 26, 2009 at 16:05:15:
Mike, Carquest sells an additive that is a rust inhibitor and it lubes the water pump. There are rad flushes you can buy and run through the engine, then flush. I know you are not in a climate that requires anti freeze but...as the others are telling you half and half anti freeze is a designed coolant that has various rust inhibitors and it transfers heat better than plain water.
