rust inhibiting coolant?
Posted by Mike CA on October 26, 2009 at 16:05:15 from (99.28.152.102):
I just drained my coolant system, and I was a bad boy. I didn't put anything in there to stop rust. I thought I would have drained it a lot sooner, but that's not how it worked out. Needless to say, I drained rust water.
I have a coolant system cleaner I plan on running through it once I get the tractor running again. After I drain that out, what is the best product out there to continue to clean out the system, and keep it free from rust?
I didn't say "anti-freeze" because my tractor won't freeze. It's garage kept, and the coldest it gets is 30 degrees outside. Higher in the garage, obviously.
So what should I get?
