Re: rust inhibiting coolant?
Posted by Bob Kerr on October 26, 2009 at 21:20:58 from (216.249.72.244):
In Reply to: rust inhibiting coolant? posted by Mike CA on October 26, 2009 at 16:05:15:
Just fill it and run till hot with regular water a couple times then fill with rain or distilled water and run that a day or two. Then drain and refill with 50/50 antifreeze and fresh distilled water and you will be good to go! The distilled water will get a lot of the scale redissolved if it has any. I got a lot of cloudy water ( dissolved scale) drained from my M and H with rain water. If you are going to just run water in it, an auto parts store should have rust inhibitor and water pump lubricant you can put in with the distilled water.
