Re: 806 Hydraulic draining/capacity
Posted by The tractor vet on October 27, 2009 at 20:52:14 from (75.19.126.148):
In Reply to: Re: 806 Hydraulic draining/capacity posted by Thurston on October 27, 2009 at 20:06:14:
Go with the filter change first and see if it will get out of the field . What owen was thinking was that maybe the PTO input shaft and or the hub on the pressure plate went south , myself i do not think so at least not yet .as you said the PTO was working and IF that is working then the shaft that runs the MCV pump and the main hitch pump was still turning as the PTO has it's own pump but no filter to clog . So if the filter was pluged and the screen and bypass were pluged then yes you will have a no hitch and no steer and the T/A will kick in and out . as for your steering wheel leak Fix it it is not a tough job to do and on a nother day when it is not so late and i am not almost falling asleep i will out line the whole deal on just how it is done and the only Special toll you will need is a steering wheel puller and two LONG 1/4 inch fine thread bolts and a snap ring pliers and one socket . So let us know how all turns out .
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
