Re: Model C Power Loss- Dies Under Load
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Dave2N on April 23, 2000 at 13:05:07 from (152.163.213.47):
In Reply to: Model C Power Loss- Dies Under Load posted by Donald Bolt on April 23, 2000 at 10:48:08:
It could be all or any of the things mentioned but I finally solved the problem with my Super C by taking off the gas tank, cleaning it, etching it and coating it. Before this, I was getting the most amazing amount of crud and corruption going into the sediment bowl.
Post A Followup
: Re: Re: Model C Power Loss- Dies Under Load
