Farmall H Steering Bolster
Posted by David Pommert on October 29, 2009 at 07:56:00 from (148.177.69.213):
The bolster seems to make a clunking sound when driving the tractor. Assumed sleeve bearing was worn. The new sleeve bearing seems to be as loose as the orginal. How much clearance should the new bearing have relative to the bolster?
