Re: Farmall 460-Multiple Blown Head Gaskets
Posted by dhermesc on October 30, 2009 at 06:25:28 from (24.248.193.103):
In Reply to: Re: Farmall 460-Multiple Blown Head Gaskets posted by Geoff W on October 29, 2009 at 19:28:10:
Scoured cylinder walls, blown head gaskets and cracked heads? I don't think changing your fuel is going to do it. Sounds like you have an excessive heat problem. Have you checked your temp guage to make sure its accurate? Do you know how clean your radiator and block are? Is your water pump in good shape and moving water? Milling the deck and head will fix it for now, but you have an underlying problem that will leave you in the same position next summer.
The 221 and 263 engines are very good solid gas engines (although thirsty under load) that with proper care and maintenance will easily give 4 thousand hours of use and up to 6 thousand of hours plus between overhauls. The engine is at least 45+ years old, has it ever been overhauled?
