Re: diesel no power
Posted by Brian in Ne on October 30, 2009 at 08:15:41 from (75.135.234.93):
In Reply to: diesel no power posted by robert in Mi on October 30, 2009 at 01:34:43:
After you check what the other fellows have mentioned, check the valve lash and valve lift, then maybe a compression check. Since you have black smoke, this sounds like an air flow problem.
