Re: Farmall 460-Multiple Blown Head Gaskets
Posted by El Toro on October 30, 2009 at 14:38:09 from (74.103.74.58):
In Reply to: Re: Farmall 460-Multiple Blown Head Gaskets posted by Geoff W on October 30, 2009 at 11:56:12:
You can never be sure when buying a used engine as to what you're getting. You rebuild your engine you will then know what you have. Have a reputable auto machine shop in your area to do the machining to the block, head & crankshaft.
Have them install the sleeves for the correct height in case machining is required. Have new cam bearings installed for good oil pressure. Have the machine shop to furnish the correct bearings since the shaft probably needs to be ground undersize. Check with them to see if the mains need to be line bored. That block may be sludged up not allowing enough oil to the bearings. Hal
