Re: Rear rim hardware on a 1941 Farmall B?
Posted by J Huff on October 30, 2009 at 20:29:55 from (75.106.107.156):
In Reply to: Re: Rear rim hardware on a 1941 Farmall B? posted by ScottyHOMEy on October 30, 2009 at 19:58:26:
I have attached the pictures, but your reply was very informative nevertheless. If square bolts are common, then it sounds like I have the "correct" hardware already, but have a poorly designed lug.
I assumed that the square bolt was wrong because these lugs don't have a "bottom" to their "box" that you referred to. It looks as though the manufacturer intended to keep the bolt from pulling out via four small dimples pressed through the sides of the "box". It didn't work.
Guess I will have to resort to a carriage type bolt or weld my own bottom into the "box" unless there are other ideas...
I am trying to put two images on here, the close up of the lug may be just a link though.
third party image
third party image
