Re: Rear rim hardware on a 1941 Farmall B?
Posted by gene bender on October 31, 2009 at 04:55:34 from (67.55.226.179):
In Reply to: Rear rim hardware on a 1941 Farmall B? posted by J Huff on October 30, 2009 at 19:08:10:
Those rims need carrige bolts. The original rims took a square head bolt 5/8 dia. So now you will need a 5/8x whatever length it measures as the steel center is thinner than the cast which was an option. The carrige bolts are on one of my tractors as the rims are aftermarket. The rims are on the B with the loader and also the snow removing machine with front and rear blade.
