Re: Model C Power Loss- Dies Under Load
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by 80 Grit on April 23, 2000 at 17:42:37 from (206.228.214.161):
In Reply to: Model C Power Loss- Dies Under Load posted by Donald Bolt on April 23, 2000 at 10:48:08:
The posts all contain good info but some are closer to identifying your probelm than others. Remove the fuel line going into the carb or remove the plug from the bottom of the carb if there is one. With the fuel turned on, let the fuel run until you catch a pint or so. You should get a full steady stream of gas without any interruption. If the stream dimenishes you have a clogged fuel source which will have to be corrected. If the above is O K, fill the radiator with coolant and leave the cap off. Start the engine. If the head gasket is blown and causing the water leak at the radiator you will see bubbles as you look at the coolant. The weepage that you see at the head gasket/head is due to lack of use of the tractor and the gasket has shrunk. This should self correct when you get the tractor fault fixed. If your problem was a head gasket or points the problem would persist at all times. You would see evidence of dirty fouled plugs and the engine would miss.
Home
| Forums
Today's Featured Article -
Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
