How far down in did it break? You'll play the devil tryin' to drill it.
If you weren't winding on it hard, and it isn't recessed too far, you might try starting it back out by tapping counterclockwise on one of the hollows in the tap with a small punch. If you were to try a drill, it's have be a very hard one and a left twist bit, but those aren' easy to find in the kind of hardness you'd need to actually cut metal, but the left twist might grab enough to get it started.
There are also some specialy tools, basically a spanner type, similar to the tool for butting rings onto the collets of angle grinders, that will get down into the recesses on a tap to wrench it out.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
