Re: Running into a wall. Need some help.
Posted by Mr. Mayor on November 01, 2009 at 17:06:46 from (24.209.131.176):
In Reply to: Running into a wall. Need some help. posted by Mike CA on October 30, 2009 at 20:49:54:
Mike, You do not have to use the type of fitting with the breakaway ferrule. Yes, it is actually the compression ferrule that breaks away from the male nut. The nuts and ferrules can be purchased separately from any NAPA store and most good hardware stores.
