Re: H missing
Posted by Bob Kerr on November 01, 2009 at 20:29:50 from (216.249.72.244):
In Reply to: H missing posted by Indianared on November 01, 2009 at 04:18:49:
Once in a while my H will act up after running for a little bit. It fires right up and runs great for a little while, but then will sputter and act horrible. It usually is moisture in the distributor cap. One place to look is on the under side of your oil fill cap and see if it has any condensation. I usually just pull the cap, rotor and backing plate off and let it dry out and it works fine. I have a feeling the problem on mine might be the vent tube going to the air cleaner might be plugged up and not letting the moisture dry out.
