Re: Re: Re: Model C Power Loss- Dies Under Load
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Phlogiston on April 23, 2000 at 19:38:35 from (63.11.121.104):
In Reply to: Re: Re: Model C Power Loss- Dies Under Load posted by Donald Bolt on April 23, 2000 at 11:30:06:
Here are a few thoughts. Make sure the air cleaner is clean. I mean pull it off and clean the unit in Kerosene. No air means no power. Make sure the fuel you are using is not last years. Drain it and get rid of it. While you are at it, make sure the screen in the fuel bowl is clean. Also check inside the tank to make sure you are not getting rust particles flowing into the carb. There should also be a small screen at the elbow that goes into the carb. Pull it, and clean if needed. As for the head, it is a fairly easy job. Get a new head gasket from your IH dealer, and torque to specs (65 lbs. if I remember correctly). First torque everything to 45 lbs, then 55 lbs, you get the picture. Also follow the correct torque pattern. Have you adjusted the valves, and set the timing?
Home
| Forums
Today's Featured Article -
The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
