Re: Re: Model C Power Loss- Dies Under Load
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Donald Bolt on April 23, 2000 at 11:30:06 from (12.75.62.19):
In Reply to: Re: Model C Power Loss- Dies Under Load posted by The Red on April 23, 2000 at 10:59:20:
If I do need to change the head gasket...are there any special tools required? If not, should I get a valve regrind while the head is off. Any other parts should be replaced before putting it back together?
Post A Followup
: Re: Re: Re: Model C Power Loss- Dies Under Load
