1st. A good tap and not one made in china. 2nd use a starter tap and then go back with a bottom tap. They make special cutting oil but light weight oil such as 10w will work as well. WD40 does not work very well, does not stick where needed. Have a air hose and keep turning untill the tap stops. If the tap stops before you reach bottom, back it out, blow it out because the shavings lot of time is what locks up a tap and keeps it from going any further, reoil and go again. Use a tap handle that has handles on both sides to keep even pressure and not a crecent wrinch.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
