Re: SA electrical problems, part 2
Posted by ScottyHOMEy on November 03, 2009 at 19:58:57 from (70.105.237.111):
In Reply to: Re: SA electrical problems, part 2 posted by Mark on November 03, 2009 at 19:32:32:
Yes it CAN fire and run if it's "technically" 180 out of time IF you move the plug wires.
You didn't say whether you're just plain not getting any spark as you crank it, or just not getting it where you expect it to be in antempt at statinc timing. From all you describe, you should be getting spark to the plugs.
Just for giggles, try the trick that will get it running if 180 out. Swap your #1 and #4 wires with each other on the cap, and your #3 and #2 wires the same. Your firing order is still 1-3-4-2, but you've moved the wires to opposite sides of the distributor to compensate for the 180.
Today's Featured Article - Product Review: Kreem Brand Fuel Tank Liner - by Staff. This condition has occurred on a few machines that we have had and fortunately we were able to borrow the technique used at the local motorcycle shop. The product that we have used is called Kreem thouh there are others on the market, this one was recommended and available. This particular product is sold in three parts, a bottle of etch, dryer, and sealer. We were fortunate enough to start the process with stern warnings from those that had used this type of product before. The horror ... [Read Article]
