Re: Mark with SA electrical problems
Posted by Mark on November 04, 2009 at 07:56:54 from (71.30.209.232):
In Reply to: Mark with SA electrical problems posted by jal-SD on November 04, 2009 at 06:48:24:
jal-SD,
At this point in time, I am willing to consider anything! Thanks for this tip....I will check it out.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
