Posted by jal-SD on November 04, 2009 at 06:48:24 from (71.38.30.28):
Have you checked the insulator on the distributor where the coil wire goes to the points? My H was giving me fits, would run good most of the time, sometimes would not fire at all. Chased the problem for quite a while & finally found a crack in the bakelite insulator on the distributor body, where the wire is bolted to the points (wire connected on outside of body, points on bolt on inside). Replaced the insulator with a plastic one from a Datsun distributor (I think that's what it was, you know about the CRS problem that us older guys suffer from on things that happened a couple of years ago) that the parts house found would fit and WHALLA - haven't had a problem since. Just a suggestion. (My $0.02 worth. jal-SD)
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
