NawlensGator just posted with the same sort of idea in last night's thread.
Good idea, at this point EVERYthing is suspect, but if the problem is at the insulator where the current moves between the coil and the points/condenser, it would be either a short as you suggest, or poor conductivity as Gator is thinking, and I'm thinking Mark wouldn't be getting as storn a spark as he is from the coil wire if either were the problem.
Still, a good thing to check. I know I had a bad insulator where the ground wire hooks up on a mag, and it was a bear to chase down.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
